Thread: 1967 911S combination oil pressure/temperature gauge question
    Thohnecker
    Sep 2016
    Cincinnati Ohio
    Question 1967 911S combination oil pressure/temperature gauge question
    I removed my oil pressure/temperature gauge to clean itÂ’s glass, and I must not be reattaching the wires properly because the temperature gauge is no longer working. IÂ’ve included a picture of the back of the gauge. I am hoping someone will be able to tell me which wires attach to which terminals, as the wires are easily distinguishable by color. I would also be happy to connect with someone via phone to talk through it, if willing. Any help is appreciated!
    Thanks, Terry
    Just use a test light and ensure you are getting power, then use a jumper and ground a mounting stud to the body.
    Aug 2020
    SF Bay Area
    Photos of my 1969 911T oil temp/pressure wires. Hope it helps.
    -Torch
    - 1969 911T Ossi Blue #3981
    Temp sender wire should be green with a black tracer.
    There is a green wire in the bundle that is a spare, maybe you swapped it?
    I don’t see a black tracer on the green temp wire.
Tags for this Thread
