Results 1 to 10 of 13
Thread: Source for this fastener ?
    Guys
    See photo ....the raised plastic shafts (4) have small clips to hold both sides of the plastic blower assembly together.
    They are corroded and need replacement. Very difficult to remove and worse to install.
    What’s good replacement ?
    Thanks for assistance
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Maybe a circlip might work?
    Spring clips,,,like radiator hose clamps.
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    and a good clean perhaps.
    Mark
    Guys......
    Thanks for input.... a good clean is planned and replating of the yellow cad.
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Aug 2020
    SF Bay Area
    Do not get the Stoddard replacements. They are far too thin, more like paper clips. Not strong enough to do the job. "e-clips" work well. I forget the size (5/16", 7/16" ?), but they work.
    - 1969 911T Ossi Blue #3981
    I measured yesterday and believe 7/16 is correct.
    Still pondering the 3 options including the e-clip .
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    As I recall they were reusable when I rebuilt mine. They went back on like a snap ring. The trick however is removing them without breaking off the plastic teats. They can become quite brittle over time.
    1969 911 E #824
    Aug 2020
    SF Bay Area
    Quote Originally Posted by xpensivewino View Post
    ^^ this. You can also break off the teats putting them back on. Ask me how I know...
    Jun 2012
    London, Ontario, Canada
    These work very well. From Amazon. I forget which was the right size but you’ll have to buy an assortment anyways. They are cheap. Not quite as stong as the originals, but that’s probably a good thing given the brittle plastic nubbins.
    I used the replated originals on the front and these on the back.
    Ravi
    Early 911S Registry # 2395
