Results 1 to 8 of 8
Thread: Drivers side Mirror hole location
    Dec 2013
    Connecticut/Florida
    My 1971 had aftermarket mirrors that were installed and corresponding holes drilled that were not correct. When we stripped and painted the body all the holes these were welded up. Does anyone have the exact location of the holes for the drivers door? I know they are obviously close to the two inside holes. Below is what I found for a passenger door option, but I don't believe the holes are in the same location?
    1971 911S Coupe - Gemini Blue
    May 2006
    CT
    Simon
    Here are the holes for the driver's side view mirror on an original door. Email me and we can figure out which measurements you need.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2013
    Connecticut/Florida
    HI Tom,
    I couldn't find your email...here is what I am looking for....Thanks, Simon
    I am showing measurements to center of the drill hole
    May 2006
    CT
    here you go. All measurements in mm
    Tom Butler
    1973 RSR Clone
    1970 911E
    Dec 2013
    Connecticut/Florida
    Just before I drill......Three questions...
    1) When installed, is the mirror horizontally level ? See first photo. Are the two red lines equal in length? If so, there would be a slight slant to the holes as the upper door edge slopes down. Or Do I drill such that holes are level?
    2) Are there two or three holes? One post I read said there is a mirror adjustment hole in addition to the two bolt holes
    3) Two different pictures below show the slotted bolt in two different locations? Is one more correct than the other?
    May 2006
    CT
    Simon
    You have a PM from me.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Guys, Can you PLEASE share those measurements with us? It would be greatly appreciated.
    May 2006
    CT
    Quote Originally Posted by formulamotorsports View Post
    You can email me at
    tomsrennshop@gmail.com
    Tom Butler
    1973 RSR Clone
    1970 911E
