Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Mecanical vs Hydraulic tensioner
  1. #11
    Quote Originally Posted by Xavier PJB View Post
    Greetings, am running a 2.0S MY1968 with original tensioners. I wonder if I keep the original system, or...
    Xavier, I'd be very surprised if your 68 engine still has original tensioners, which were the open reservoir type.
    I agree with the recommendations for 930 tensioners and upgrading the idler arms. Also make sure that the original rubber chain rails have been replaced.
    If your engine still has original 68 idler arms or rubber rails, you might want to pull a rocker arm to make sure the 68 non-bushed versions were upgraded as well.
    Jon B.
    Vista, CA
  2. #12
    Nov 2003
    Santa Monica CA
    +1 for the 930 tensioners (my tech calls them 053) and the wide idler arms with copper bushings and the safety clamps on the rod sticking out of the tensioner. Had it that way for over 20 years without a problem
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
  3. #13
    Aug 2012
    France
    Thank you very much for all your feedback, very valuable - as usual on this wonderful board.
    I will soon remove the covers and will inform you of the findings and the upgrade I'll make (930 + seems to be the way)
    Any references for the wide idler arms with copper bushings ? Or are these standard alongside with the 930 tensioner ?
    Cheers
    X
    O-G 26 - Early911S 2407
  4. #14
    Nov 2003
    Santa Monica CA
    I think all wide idler arms come with copper bushings. the ones without bushings are factory issued from the past. The idler arms without the bushings would gall or scratch the post they were on and cause a failure of the tensioner.
  5. #15
    I guess no one has had a non bushed idler sprockets (chain wheel) seize on the axle of an idler arm. They were early parts maybe up to 69.
  6. #16
    Aug 2012
    France
    Ok, So this is what I have in my 20S engine :
Size:  144.1 KBName:  IMG_4856.jpg
  7. #17
    May 2006
    CT
    I would add the safety clamps
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
  8. #18
    Aug 2012
    France
    All right, where to source please Tom ? Any place in Europe ?
  9. #19
    May 2006
    CT
    I can supply them. PM me with your email for details.
    Tom Butler
    1973 RSR Clone
    1970 911E
  10. #20
    Aug 2012
    France
    Not much oil on your engine Tom...
    PM sent.
