Results 1 to 9 of 9
Thread: Help with parking brake guide assembly
    Does anyone know what part #50 looks like?
    It isn’t listed in the Porsche part catalogue and it wasn’t on my car when I disassembled the parking brake cable
    #50 is in the swb PET - it is # 695.424.611.00 and available at the pelican-
    https://www.pelicanparts.com/More_In...424-611-00-OEM
    Dec 2013
    Connecticut/Florida
    I don't see it on my 1971. Strange that it shows up
    1971 911S Coupe - Gemini Blue
    Its a washer with a 6mm hole and about a 12mm o.d. Without it the cable will just pull thru the guide.
    This would work?
    It is more of a semi-soft nylon grommet, really there to keep the tube from flopping around. The pelican link shows what it looks like. The BelMetric washer would not do the job. Best to get the proper part.
    Take care,
    Brad
    Brad Davis
    RGruppe #691
    Early 911S #1547
    Thanks everyone for the info
    Does anyone have a picture of it installed?
    I thought you meant the washers, I think that guide is used on SWB trailing arms. What year car do you have?
    Thanks ed for the response
    This would be for a 1971
