Thread: Rear 1/4 window and trim question
    Dec 2013
    Connecticut/Florida
    Hi,
    I wanted to confirm if I have this correct? You can see the headliner shows on the outside at the edge of the black molding. I assume I need to trim the white headliner back so that it doesn't show?
    1971 911S Coupe - Gemini Blue
    Yes, you need to trim. You do know there are different thickness washers called for under that trim strip?
    Dec 2013
    Connecticut/Florida
    Thanks Ed! and yes, I have the 3 sizes.
    For a white headliner, is that quarter window trim white or black on a 73s?
    They were white, don’t know if you can get it anymore.
    They were white, don’t know it uncanny get it anymore.
    VW had similar trim. On German eBay it was offered for the longest, it still might.
    Richard
