Results 1 to 10 of 11
Thread: 1970 2.2L 911S engine complete with MFI
    Feb 2007
    San Diego
    *SOLD*
    I have a spare original 70 911S engine I would like to sell. Engine number 6301330 with the correct 911/02 type number. These engines are in my opinion the most fun to drive of all the early engines. Forget the 2.0L as a fun engine - the larger displacement 2.2L, revised cylinder head/combustion chambers fix the peaky issues with a 2.0, more torque, the MFI is the sexiest induction that can produce 10 more HP than carbs and with the all metal induction these engines howl. They rev like crazy, put out great horsepower - easily 200hp when done right or more. 66mm short stroke with 84mm 9.8:1 compression forged pistons, 36mm intake ports 35mm exhaust.
    It is a simple install to any 1965-1973 911 (or 912). Why hot rod your engine when you could do this one and save the stock/original engine, later you could re-unite your original engine and sell off the spare if you wanted. This is a core, I got it from an old retired mechanic friend. Turns over fine but I would assume it needs everything but there is a chance some of it is good inside and won’t a full rebuild. It was rebuilt a number of years ago but converted to carburetor cylinder heads - comes with 2 complete sets of heads - 911S spec MFI heads included separate, my machinist started on these by surfacing them and installing new guides but no sizing or valve work done (my guys work is excellent so don’t think you will have to redo this or worry about bad work).
    Comes with:
    009 2.2S MFI pump, correct 2.2S throttle bodies and stacks Eurometrix has rebuilt these TBs in the past, original steel MFI air cleaner with cold start rail (these sound bitchin over the plastic stuff), 007 2.2S distributor. Also has the original fan/alt/shroud, sheet metal, exhaust, flywheel/clutch.
    Just want to sell this to fund some of the house remodel so the wife doesn’t leave me.
    $**,*** Located in San Diego area, can deliver within 100miles.
    Just spoke with Henry at Supertec today, he would be happy to rebuild it. I can drop off at his shop in Fallbrook no cost.
    Feb 2007
    San Diego
    More pictures, I have the air cleaner but it’s hard to get to at the moment, will update pics shortly.
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Nice motor Mark.
    Far better that the spare engine leaves rather than the wife.
    Mark
    Junior Member Bob Miller's Avatar
    Apr 2010
    Maryland
    Hi. I'm very new here. It appears that you have another set of S heads. Would you consider selling those separately? My best, Bob
    Feb 2007
    San Diego
    Quote Originally Posted by Bob Miller View Post
    No sorry. The heads mounted on the engine are for carburetors, the MFI heads are included to replace the other ones during a rebuild.
    Bonus - the old heads will be worth $800-1000 in salvage value so you can look at that as a future discount.
    Feb 2017
    Auckland NZ
    This appears to be a good deal.
    Mark
    No 'stars' preceding or following the engine serial number...
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Quote Originally Posted by mac73s View Post
    Look closer. I see both of them.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Feb 2007
    San Diego
    I have a bunch of cameras, sometimes use the wrong one for the job, here is a better picture..
    I'm glad for you and any potential buyers that the 'stars' are indeed present - good job in posting additional photos.
