Selling 2.2S MFI parts
2.2 S MFI pump, rack returns, #009
2.2 S Air Stacks, both have casting numbers 911 110 303 1R. Both stacks have 4 notches on the top to accept aftermarket filter housings.
2.2 S Throttle bodies two driver side with casting numbers 911 110 101 2R and 911 110 101 0R and bare throttle body 911 110 101 2R
The two throttle bodies whose casting numbers are 911 110 101 2R are the pair that came with the injection originally. One had been stripped to rebuild or something. I’ve included another intake part number 911 110 101 0R which is also a 38/36 as a donor. I believe 911 110 101 0R is also a 2.2S throttle body but can’t find its casting number in id records. It is a driver’s side but remove the throttle linkage shaft and it becomes a passenger side or use it as a donor for the bare throttle body.
The pump and throttle bodies should be rebuilt and are being sold as cores.
The pump, throttle bodies and air stacks have the important numbers that identify it as being correct 2.2 S MFI, which of course is important to the value of any 70/71 911S. Offered at $7500
2_2S_0131558405068.jpg2_2S_0021558405068.jpg2_2S_0031558405068.jpg2_2S_0041558405068.jpg2_2S_0161558405068.jpg2_2S_0221558405068.jpg2_2S_0171558405068.jpg
