Results 1 to 10 of 10
Thread: Is this right orientation for install?
    Guys
    Gasket/seal for front hose feed .
    Before I glue in place want to determine if this is correct orientation?
    Thanks for assistance
    FrankName:  90D0F5BC-FCA1-41C2-81A7-14DFBEF901CF.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Dec 2013
    Connecticut/Florida
    I may have done it wrong also - but I put the straight area against the support for the strut
    1971 911S Coupe - Gemini Blue
    Simon
    I had also thought about that location ....
    Let see what the experts come up with
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Here is photo, based on the dirt profile/shadow which looks Like a thiner profile on the right side , Think where I have it positioned think this is right location .
    Wait for more comments
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Aug 2020
    I believe the flat goes to the outside, as you have it more or less. Here is the driver's side, from below, before I replaced them. Pretty sure it's flat to the outside (left of pic from below).
    - 1969 911T Ossi Blue #3981
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by TheTorch View Post
    is this a 69?
    Quote Originally Posted by Simonjjb View Post
    +1...pretty sure I have photos of original gaskets in place...will take a look and report back.
    May 2006
    CT
    Here is a photo from my '70E prior to disassembly.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Aug 2020
    is this a 69?
    yes it is from my 69
    I found the it only fit well with the flat in the correct position. I believe the flat goes towards the strut. Here is the passenger side from above. I am fairly certain I put the new ones in with the same orientation as the originals.
    Last edited by TheTorch; 01-31-2021 at 03:33 PM. Reason: ps and added photo. caveat
    Senior Member rmakosaito's Avatar
    Dec 2010
    Denver CO
    I'm disassembling a '71 targa - here's my documentation of the right side. Not sure how helpful this is because this one doesn't have a flat side, rather it has a cutout for the strut mount.
    Registry #1917
    1971 Condagrun 911T targa
    1974 Indisrot Carrera coupe (US)
    1972 BMW Polaris 3.0 CS
