Results 1 to 7 of 7
Thread: The One . . .
    The One . . .
    . . . damaged in the last set o' storms, here in CA
    https://www.yahoo.com/news/drone-vid...191356409.html
    Might be awhile before they fix this
    Aug 2017
    el sobrante ca.
    looking at the topography, there is a good chance that the failure was due to poor maintenance of the culvert going under the road..... Was it blocked with debris before the storm? Or , was it just a catastrophic mud flow?
    '. . . Is This The End . . .'
    '. . . Soaring mountains on one side of the road and the Pacific Ocean on the other: It was 1956 and Gary Griggs was experiencing California State Route 1 for the first time.
    He was a child, but in the following decades he would drive this scenic stretch of road, called the Pacific Coast Highway, dozens of times. He'd also learn how fragile it is.
    In 2017, Griggs consulted on a major repair to the highway as an erosion expert. Now, he says the iconic road's days may be numbered – at least in its current form.
    Future generations may say “it was great while it lasted,” the University of California, Santa Cruz professor predicted.
    Frequent damage has long plagued the PCH. Most recently, in January, yet another chunk fell into the ocean following intense rainstorms, which created a debris flow that overwhelmed water drains more than 100 miles south of San Francisco.
    This time, a 150-foot piece of road broke off, the state Department of Transportation said.
    Repairs are scheduled to be complete in early summer. For now, travelers must turn around when they reach the gaping hole – there's no bypass in that remote stretch of road.
    As global temperatures warm because of human-caused climate change, Griggs says the conditions that lead to this kind of damage will only increase.
    The PCH's days are numbered, Griggs said. It's "inevitable” one day the fixes and repairs won't be enough or will be too costly to save the highway.
    California's fragile wonder is 'one of the most scenic drives in the nation'
    The journey is the destination on California's Highway 1.
    The two-lane road hugs the California coast for hundreds of miles. In its most famous stretch between San Francisco and Los Angeles, the roadway is carved into steep, mountainous terrain around the rugged Big Sur coast.
    Griggs calls the region a “geological nightmare” – a mix of hard and soft rock that makes development a challenge at best. It's also at the edge of two tectonic plates.
    That's part of the reason it has remained a relatively rural stretch of road with few of the tourist attractions you might expect from a world-renowned destination.
    “There are easier ways to go North or South, but there aren’t any more beautiful ways to do it,” said Lesley Ewing, a coastal engineer with the California Coastal Commission.
    There are no strip malls and few gas stations, said Paula Twidale, senior vice president of Travel for AAA.
    “That’s what makes it iconic," she said. It's “one of the most scenic drives in the nation."
    The highway climbs from sea level to hundreds of feet above the ocean, wrapping around the terrain to give drivers glorious views – and pull-offs to safely enjoy them.
    Given the road's location, it is no surprise that Highway 1 is frequently damaged.
    For decades the highway has struggled to make it through a calendar year without an incident that closes a portion, Ewing said.
    That's to be expected from a "highway at the edge of the continent,” said Kevin Drabinski, a Caltrans spokesperson in California's Central Coast
    Usually damage occurs because of a combination of weather and geological activity, Drabinski said.
    But what is changing: The frequency and severity of that damage.
    Effects of climate change endanger future of Pacific Coast Highway
    Although the highway is celebrated for its ocean views, it is not rising seas that worry Griggs the most. It's fires and rain.
    Experts are hesitant to attribute an individual incident of road damage directly to climate change. But the effects of climate change are creating conditions that worsen Highway 1's existing problems.
    Huge wildfires are increasingly dotting California with massive burn scars: scorched earth with little vegetation to help hold the soil together.
    Overall in 2020, nearly 10,000 fires burned over 4.2 million acres in California, more than 4% of the state's roughly 100 million acres of land, making 2020 the largest wildfire season recorded in California's modern history, according to CalFire.
    A burn scar in steep terrain, like that found in Big Sur, creates perfect conditions for mudslides and debris flows.
    All that's needed is a deluge of rain – which, in coastal California, is also happening increasingly frequently.
    In fact, the types of big storms that can batter California with heavy rain and snow are projected to increase in intensity in upcoming years because of climate change, UCLA climate scientist Daniel Swain said.
    "There's a lot of evidence that atmospheric rivers will become more intense as the climate warms," Swain said. While we may not see more atmospheric rivers overall, the ones that cause problems will become stronger, and there will be more major storms, he said.
    Made visible by clouds, the ribbons of water vapor known as atmospheric rivers extend thousands of miles from the tropics to the western U.S. They provide the fuel for the massive rain, snowstorms and subsequent floods along the U.S. West Coast.
    These "rivers in the sky" are responsible for up to 65% of the western USA's extreme rain and snow events, a 2017 study said. Though beneficial for water supplies, these events can wreak havoc on travel, trigger deadly mudslides and cause catastrophic damage to life and property, the National Oceanic and Atmospheric Administration said.
    One well-known nickname for an atmospheric river is the "Pineapple Express," which occurs when the source of the moisture is near Hawaii.
    Swain said that it's the powerful atmospheric river storms that have historically caused problems with the Pacific Coast Highway, which "is not in a very geologically stable position even in the best of times."
    Most of the land slippages along the highway are caused by land on the upper, mountainous side of the highway – such as during landslides, mudslides and debris flows – which are often worsened by California's ferocious wildfires, he said.
    Swain said climate change is expected to worsen both the frequency and potency of wildfires in California, adding yet another layer of concern for vulnerable Highway 1.
    What's next? California Coastal Commission expects adaptations
    California has been planning for Highway 1's future for years and the state's Coastal Commission has been charged with protecting the highway, Ewing said.
    Californians should expect a two-lane road will continue to span most of the state's coastline. Studies and plans have been made to ensure the highway continues to function.
    But adaptations will need to be made.
    South of San Francisco, a section of Highway 1 plagued by rockslides was covered by a tunnel in a project that cost hundreds of millions of dollars, the Metropolitan Transportation Commission said in 2013.
    Breathtaking views are still available in a mile-long section for pedestrians and non-motorized vehicles.
    Ewing anticipates more solutions like that one will be needed in coming years and decades.
    “You can keep putting these Band-Aids on it,” Griggs said, noting that adaptations are especially challenging in the unforgiving terrain of Big Sur. Simply retreating the highway inland slightly isn't an easy proposition.
    Some repairs made to the Highway 1 are now made to last for decades in anticipation that damage will continue, Caltrans' Drabinski said.
    It will take "innovative designs" to protect the road, he said. For now, travelers can expect that "the general experience of that road will still be there."
    https://www.usatoday.com/story/news/...-1/4560256001/
    One of my All-time Fave's --- a place that reminds me of why I have a car . . . and what they're for . . .
    https://www.early911sregistry.org/fo...l=1#post661765
    Cue the 'tiger-sound'
    I'd Make It a Toll-road . . .
    . . . = 'pay-to-play' . . .
    . . . I may never make it to the 'Ring, but --- in the mean time . . .
    Nürburg Ring = 17.56 mi/28.3 km + 174 turns
    The One = 90 mi/145 km + 381 turns
    Deutschland's may be gruener --- but ours has . . . . landslides. For millenia --- this whole area's been a battlefield . . . the land always losing. And The One wanders through it all . . . a more-than-occasional casualty
    Kleptoforia's been a swipe-of-a-credit-card away from insolvency --- for years, now, so . . . no idea why CalTrans bothers, here . . . but bless their hearts
    El Ninos' wash stretches of it away almost every year . . . and they re-pave it
    Rocks fall on it just about all the time . . . and they sweep it clear --- right away. And check out that cliff-side . . . steel-cable catch-netting
    And then BIG parts'll just --- fall into the sea. They'll carve a new one
    Why?
    Why ask why?
    To help maintain this Expensive Anachronism, how 'bout charging twenty-bucks a car to drive it?--- maybe fifty for a Motor home? . . . + another fifty for a trailer?
    Should take care of some of the Really Casual Traffic --- + maybe wipe-off some those double-stripe sections while you're at it?
    I'm in!
    Aug 2017
    el sobrante ca.
    Obviously there are places like Devils' Side where costal erosion takes the road. But this is an example were proper care could have averted the damage.
    What needs to be done is that at all drainage culverts that go under the road need to be removed and greatly enlarged. Also a hot shot team armed with a Gradall, should be on a rolling stand by with observers checking vulnerable areas for trees and debris that may block these conveyances during the storm....
    Under no circumstances should the road ever be taken out of service .... Its "value" to California warrants all expense to maintain.
    No roadside barriers..
    At least this time it’s south of Big Sur.
