Results 1 to 7 of 7
Thread: ‘69 Fog Light Switch Question
    Senior Member nvr2mny's Avatar
    Mar 2012
    Kansas City
    I’m putting an amber rear fog light on our ‘69 Polo hotrod. Not running front fogs. My question is, which switch lens color was correct for LWB cars, green or yellow. I want to run a single stage switch as I’ll never put lights up front. In addition to the color question, a part# would also appreciated. TIA Name:  76221F19-D65C-411C-8C6A-F5E4233F2F10.jpg
    Reg#2218
    That's pretty trick. I like it.
    Mar 2012
    Kansas City
    Thanks JP. Should be pretty special when it’s done.
    Reg#2218
    Not sure about the knob but a single stage switch would be 901.613.503.20 or 902.613.511.91. Same switch, just different numbers. I've got a drawer full of them (sans knob) if you need one.
    Sep 2006
    Vancouver, BC
    I have a switch from an original '70 and it is yellow. Not sure if that's definitive.
    Dec 2010
    Southold, NY
    Why strain your brain. If it's a yellow light, use a yellow lens.
    Mar 2012
    Kansas City
    Quote Originally Posted by ejboyd5 View Post
    NOT a bad idea!
    Reg#2218
