Results 1 to 7 of 7
Thread: Large Durant mirror rebuild
    Sep 2020
    Altoona, PA
    Hello All!
    I’m in the process of restoring my ‘71 T and found a large Durant mirror locally that needs a new mirror glass because the silver has come off the inside.
    I busted out the glass because it was already bad, so no loss. I found inside the mirror housing was just some sealant/glue to keep the lens from rattling.
    There was more sealant in there, but it just scrapes off.
    The black plastic retainer trim ring was next to come out. So I heated some water in the microwave and soaked the mirror face down in a container for about a minute. This softened the black ring up enough that it can be carefully popped out prying from the inner edge. The mirror housing has a crimp like the gauge bezels do, but when the black ring is softened, it will come out with a little persuasion.
    The mirror glass is 4 3/4” in diameter and .115” thick. You could probably get away with 1/8” mirror glass.
    You can see there is a small lip on the backside of the black plastic ring to center the glass. I’ll have a new piece cut locally and repolish the stainless before reassembly.
    Hope this helps someone out that may be afraid of opening up their mirror.
    Dan
    ESR member 4002
    1971 911T project
    1999 Boxster
    2001 Porsche 996 Cabriolet 4
    Nice
    pictures of after the glass was out and just the ring, prying would be nice....... have those?
    Do a lot more pics when putting back together..... the devil is in the details.....
    1970 T
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Thanks for providing that measurement. I plan on replacing my glass as well in the near future. Now I can get the glass ahead of time.
    BTW: What is the glass thickness?
    Brent
    '70 911S
    '68 TR250
    Actual size is 120mm x 3mm.
    Sep 2020
    Altoona, PA
    Quote Originally Posted by bru15 View Post
    Nice
    Sorry, but I do not. I just used as big of a flat blade screw driver that I had, around 3/8” across the blade as I didn’t want the edge of the blade to dig into the black ring. I did use a mini (think eyeglass size) straight screwdriver to “pop” the outer edge out from behind the perimeter crimp. I then put the big straight screw driver about the same location but back against the stainless mirror back.
    I think the trick is heating the plastic ring to make it soft, so you don’t have to worry about cracking it. Name:  9272CB25-C00D-43B4-B04D-934BF3B97395.jpg
    I did do my prying down at the edge closest to the mirror mount, that way if I did nick the stainless edge, it wouldn’t be easily seen. I didn’t, so it didn’t matter anyway. Just take you time and don’t get into gorilla mode, you’ll be fine.
    ESR member 4002
    1971 911T project
    1999 Boxster
    Sep 2012
    Toronto
    Quote Originally Posted by LiveFromNY View Post
    Thanks for the measurements.
    I took mine apart tonight.
    Dan (OP) asked about the glue/sealant on the inside of mirror. Turns out it's a round rubber gasket. (top right in photo)
    Here's how I did it: I removed my glass from the outside, using a number of thin pointed non-serrated table knifes. Started by inserting tip of first knife blade between black ring and the lip on outer circumference of housing. Once I got the first blade in, I started to insert additional knife blades on either side of first blade. Once I had the fourth blade inserted, the black ring started to separate from the glass by about 1mm. Then I started to pry between the glass and the black ring, until the ring came free. Didn't heat up the mirror to do this.
    Brent
    '70 911S
    '68 TR250
    Sep 2013
    Kalamazoo, MI
    I did this same rebuild many, many years ago. To source the new replacement glass I bought a reproduction and borrowed the glass from it to go back in the oem mirror. Easy peasy.
