Results 1 to 9 of 9
Thread: Production Volumes by Year
    Is there an accurate chart of production number for each year anywhere?
    (I found the '68 thread)
    I keep Pat Paternie's RED BOOK on my desk for quick reference...
    Hope this helps,
    cm
    Jul 2006
    Switzerland
    agree!
    2005 edition i have, and still the best source.
    Registry member No.773
    Oct 2008
    Burford, ON, Canada
    Some of the sources, Red Book included, have some errors, others are quite wrong. Sometimes even the Factory numbers are not quite right. Another problem is how the "year" is defined. From 1968 the model year was coded into the VIN, and before that it was murky. Here on ESR we often talk about the 1964 911, which is defined as the 232 cars produced (according to the production record book) in calendar year 1964. But this does not mean that the VIN range for this group is the full set from 300001 to 300232. Indeed, this group includes cars up to 300235 with one car never completed as far as we are able to determine, and a few more completed in calendar year 1965. A lot of these cars were different in many ways from the rest of the 1965 Model year group. But how to define that 1965 model year? The Factory would have us believe everything was just early production 1966 model year. There is a huge thread devoted to the transition from 1965 to 1966 model year. Production numbers for what I (personally) would define as 1965 model year would include between 1900 and 2000 cars (which also includes the 1964 subset and the 901 sub-subset). Then try to define the 1966 model year; there is the murky transition from 1965 and an equally murky transition into 1967. The Factory defined the first VIN of 1967 model year as 305101. Does this define the last VIN of 1966 MY as 305100? Nope, not even close. We have discovered through research (big thread on the 1967 Deluxe) that "probably" the last 1966 was 304702, and from 304703 to 304959 were 1967 Deluxe subset. Between 304960 to 305100 the VIN range was not used. A similar gap exists in the Porsche built 912, but not the Karmann built 912. While 1966 and earlier we had just the 911 Coupe, in 1967 we had the 911 & 911S in Coupe and Targa versions. In 1968 this exploded to 13 911 variants. In 1968 and 1969, the VIN range began with last digits of 001, but from 1970 the range began at 011 with the first 10 reserved for the Factory to play with. Sometime after (1984?) some (all?) began at 061 to allow the factory to play with a larger reserved range. Through my own research I have also determined that the 1971 911S Coupe had a gap of approximately 236 in the middle of the year; but this is the only mid-year gap I have found, so far. But yeah, I have what I consider a fairly comprehensive list for my own use.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Dave,
    I d love to see this list of yours, ....
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Having worked for two European car manufacturers, I can tell you there’s no set and consistent policy for establishing model year designations, at least for those two manufacturers. Sometimes it came down to holding open a model year for a few months to get a certain sales number. Unless someone has, or had, direct contact with someone in the head office at the time, I’m afraid we’ll never really know what really happened for model year 1965 at Porsche, especially with the plant juggling the production of three models that year. Porsche has a pretty consistent way of setting model year designations, but who really knows what happened in 65? As my wife says, when you don’t know you make up stories.
    John Schiavone
    Connecticut
    Jul 2006
    Switzerland
    thx to all, excellent insights..Dave, John.
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by haul View Post
    Dave,
    Sure, I will email my long hood list.
    Jul 2014
    bavaria
    Dave,
    as always, most interesting...will start
    work with it...
    thanks
    mille grazie
    br
    stay safe&healthy
    haul
    erwin_loves_polo
