Thread: Crankshaft, damaged journal, 70.4
    Sep 2013
    Kalamazoo, MI
    I have a 70.4 counter balanced crankshaft with a damaged journal from a spun rod bearing. Is this something that can be repaired? If it can be and there may be a buyer, I will list this for sale in the classifieds.
    Do you need another crank?
    Not sure what you need.
    I have one done from a 1970 that went to a 2.4
    1969 911T Coupe Blood Orange (Vivy)
    Sep 2013
    Kalamazoo, MI
    I'm sorry and need to clarify. I am not looking for a new crank. I'm looking to empty my garage. I'm hoping someone could use this, or it goes to the recycler.
    Senior Member 30westrob's Avatar
    Mar 2016
    SE Pennsylvania
    Yes, the crank has value. I would check with a engine machine specialist such as Olies about approx. repair cost so you can estimate value. I have a 2.4 S with 40K mi. since a properly repaired crank was used during rebuild. Rob
