Thread: FS: Two Fuchs 7" x 15" Carrera RS finish 73 dates with caps
    Dec 2017
    Hudson Valley NY
    I have two very cool 7" x 15" Fuchs
    They would work on 73 Carrera or 74 Carrera. Recent cosmetic resto on front. Checked for true and staight. Ready to bolt on to your classic 911. Factory correct center caps included.
    Dates 8/73 & 10/73
    20210208_182244.jpg20210208_181945.jpg20210208_181951.jpg20210208_182511.jpg20210208_182335.jpg
    They would work on both 73 and 74 Carreras as you state but are only correct for 74 I suspect.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Dec 2017
    Hudson Valley NY
    Correct if you care about exact dates the 73 Carrera would have the 3 Prong dates << pre 7/73 dates. Also to be clear to any possible buyers these are finished in the correct RS not RSR. They have the frosted finish only on the down step of lips.
    Oct 2018
    Orange County, California
    Do you know the back space? I would like to use them on my 72T.
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    Feb 2020
    NW CT
    You can use them on your '72. Whether you need a slight roll of the lip will depend on the tire you use, your car (how the suspension is set up, etc), and your style of driving. Worst case is a near imperceptible rolling of the fender. Plus, with the exception of the center cap, I believe the .11's are identical to the .01s (weight and lip), and you can glue the three prong cap into the .11s. The later .41s are heavier. To be clear, always happy to be corrected, but I have a set of .01s and .11s and they seemed identical in every way.
    This is a nice set, btw.
    MBR #3926
    '71 911 T Targa "Rick White"
    '71 911 E "Karen"
    '70 S/T
    '16 CD
    '10 E61 "Vomit Comet"
