Results 1 to 10 of 18
Thread: SWB to LWB
    SWB to LWB
    Good evening all. First time poster about somthing I have not been able to find a clear cut answer to. I recently inherited a 66 911 that my father and I put a SBC into in 20 plus years ago. When he purchased the car it already had body panels off of a 72 (so he was told). Now when you look at the side of the car the rear tires do not sit square in the rear fenders. Now I know in 66 it was a SWB, and in 72 it was a LWB. So what I want to know is if I can bolt on LWB rear trailing arms to correct my problem. And if so what all I will need to do. Thank you
    May 2014
    South East USA
    I really like seeing photo of the difference in the swb vs lwb.
    Hope you find the fix.
    Dec 2010
    Southold, NY
    Let's also see some photos of the SBC installation.
    Dec 2015
    NE Michigan
    I think you will also need lwb axles and cvs. Spring plates? Sure others will add to the list.
    Quote Originally Posted by ejboyd5 View Post
    I dont have any good pics of that at the moment. I am out out town away from the car. I do have a couple more of the bottom tho.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    I'd change the body and leave it SWB
    Quote Originally Posted by uai View Post
    I really like the later modle wider look. And in the future I may change it again but for the time being I want to to leave the body alone.
    Aug 2009
    SF Bay Area
    Bolting LWB trailing arms to a SWB requires replacing the mounting brackets on the torsion bar tube. Not an insurmountable task but more than just bolting parts on.
    Jim
    Jim
    Have you by chance done this before? What all parts will I need and off of what years? Thank you
    Aug 2013
    Westlake Village, Ca.
    Agree with this
    Scott
    303581
