Results 1 to 10 of 10
Thread: Parking Brake Cable Assembly - 71S
    Dec 2013
    Connecticut/Florida
    Hi,
    Just want to make sure I have installed the metal tube and cable correctly into the rear parking brake? Does this look correct? Also, some pictures of the front brake as well - before and after......Thanks
    1971 911S Coupe - Gemini Blue
    Show me the other end of the cable, got both the washers in place, are both expanders within the brake shoe tabs?
    Dec 2013
    Connecticut/Florida
    Dec 2013
    Connecticut/Florida
    this is a better photo
    Oct 2010
    Southern Ca.
    Looks correct , Im more concerned about the trailing arm spring plate hardware . Why is the grade 10 hardware zinc plated ? , it was not originally . Zinc plating causes hydrogen embrittlement .
    I hope the hardware was baked after plating .
    If it matters to you on the spring plate bolts the top one faces in, the bottom faces out.
    Dec 2013
    Connecticut/Florida
    Thanks - I will change them out.
    Dec 2013
    Connecticut/Florida
    Ed, just to be certain. You are saying the Yellow bolt circled should face the other way correct?
    May 2006
    CT
    Ed and Rich .......Isn't also true that the caliper attaching bolts should be black phosphate?
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Yes, the top bolt you have circled would be installed facing inwards.
