Thread: 930 Rear Trailing Arm Pick Points
    Jul 2012
    Annapolis MD
    Im going to be fitting 930 arms on my rsr build. I have sourced new boxed pick points from Aase. Name:  RSR_mount1520547606.jpg
    Does anyone have the dimensions or jig needed to fit these? I dont want to wing it. I have some rough dimensions of the differences between the 911 and 930 points but looking for a solid dimension or procedure. I am hoping this can be accomplished without the use of a frame jig. Any advice is appreciated. Thanks.
    RSR brackets like u have were welded directly on the original long arm pick up points. If your torsion tube is straight, and u trial fit those pieces, do some measuring, I think u will get it figured out.
    Jul 2012
    Annapolis MD
    Thanks. I have the rough dimensions to work with and some pictures out of BA Performance Book. Im sure I can figure it out. Just wanted to see if anyone that had done this in the past had anything that they would add.
