Thread: glove box buffer - which one is correct?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    @all
    I was asked about the glove box buffers for the early cars, and obviously a search in the PET did not bring up the correct result.
    Part 999 703 064 50 does not make the impression to fit and I do have the feedback they do not fit at all!
    see below...
    Allen had posted a pic of the early type over here #18, Frank also...
    https://www.early911sregistry.org/fo...ove+box+buffer
    On inspection of my 65 I had these installed - see below - and these do look to me, as if these are the ones used in the 356C, part 999 703 035 50.?!!
    What is the correct item/result, which part is to be used?
    Could you please post a pic of what you do have?
    thank you in advance
    with best regards
    stay safe&healthy
    haul
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    the last pic and Allens foto show the same early type...the one on the last pic is just disintegrated.
    if you have a big hole on the dash you need the early type---small hole later type..
    no hole on the dash buffer is on the glove box
    Jul 2014
    bavaria
    I did ask some friend with cars....
    following some pics of 65 to 66 cars....
    the redone car is easily to be found because of the new 356C style buffer
    erwin_loves_polo
    Jul 2014
    bavaria
    some 67 68 69
    erwin_loves_polo
    Jul 2014
    bavaria
    two more
    one late 356,
    another 65, folded..
    erwin_loves_polo
    Jul 2014
    bavaria
    Joris had been asking the question over at the 356registry----
    http://forum.porsche356registry.org/...p?f=13&t=52120
    I would say: issue solved...?
    br
    haul
    erwin_loves_polo
