Thread: Removing rear wheel bearings in-situ
    Senior Member VA_alfa's Avatar
    Jan 2013
    Shenandoah Valley
    Hello friends,
    Can the rear wheel bearings be removed in a SWB without taking off the banana swing arms?
    I need a bearing replacement but don’t want to remove the swing arm if possible.
    Alex in VA
    Alex in Virginia
    Looking for:
    ward to driving my car!
    Early 911S Registry # 2863
    I use a hub grappler. It’s a professional tool and expensive but have yet to find a wheel bearing it can’t handle.
    A swb rear bearing is entirely different than the lwb type. It would be best to source a shop manual for this project. Yes, it can be done in place.
