Thread: H1 Chrome Replacement
    Hi folks! Looking for some help. I tried searching the net on how to replace the chrome trim rings on an H1 without any luck. Any leads appreciated or if you have done it before any tips you can send my way would be much appreciate. In particular I'm not sure how to best disconnect this flexible adjustment arm in the picture below. And how to remove the adjustment screws from the chrome trim (if necessary). Thanks in advance!
    May 2014
    South East USA
    In many cases.... If you buy new chrome rings.... They come with the 4 screws pre-attached.
    If you remove the 4 screws...I have seen some replace the little keeper... With a nylon lock nut. Which will act like the keeper.... And stay in place.
    who is selling H-1 trim rings.......that are Good?
