Results 1 to 10 of 10
Thread: Shift Coupler Tunnel Cover Question
    May 2006
    CT
    I am about to install the grilled shift coupler tunnel cover on my '70 project. Is there anything that goes between the cover and the top of the tunnel or are the grills open to the inside of the tunnel and the coupler?
    The PET shows nothing but I have seen some covers with some insulating material inside of the cover.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by tom1394racing View Post
    FYI- My 1971 has hard black insulation
    1971 911S Coupe - Gemini Blue
    Seems we will need photos and more details on this material
    And if consistently used for 70/71
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Aug 2020
    SF Bay Area
    FWIW my 69 had what looked to be original stiff tar-like insulation under the vented cover. Some pictures:
    - 1969 911T Ossi Blue #3981
    Feb 2007
    Cheshire, UK
    Some photos of one I have , hopefully of help:
    Tim
    Early 911S Registry #1167
    Dec 2013
    Connecticut/Florida
    Quote Originally Posted by Bantam View Post
    This is the same as my 1971
    May 2006
    CT
    Thanks everyone. A big help!
    Tom Butler
    1973 RSR Clone
    1970 911E
    Dec 2010
    Southold, NY
    Depends on whether or not your car had the auxiliary heater. With a heater the grille was open for air movement, without a heater the tarred cardboard would be used.
    May 2006
    CT
    Trying to get close to original look. NAPA sound deadening panel cut to size.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Very thick roofing tar paper is nearly a dead match for the original stuff as well. It’s probably what they used. That’s what I cut mine out of..fyi Steve
    1969 911 E #824
