Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Sportomatic Adjustment Help Needed. I'm tearing my hair out!
  1. #11
    Junior Member
    Mar 2011
    Australia
    Hi Richard,
    You can see the "+" clearly on mine. On 72s this spade connects to a blue/yellow wire. The negative connects to 2 brown/white wires.
    Do you still have the black diode connected between the spades? This diode stops the shifter contacts from burning out.
    Name:  sporto diode.jpg
  2. #12
    Hi all,
    Thanks for all your help to date.
    I've finally tracked down the problem. Both of the non-return valves in the inlet manifold are leaking and faulty. When I rebuilt the carbs the vacuum each inlet was making reduced vacuum and so this problem came to life.
    Next issue is finding replacements for the brass valves part # 905 116 725 00 as they are NLA.
    Thanks, Richard
  3. #13
    Jul 2008
    South Florida
    Sorry that's the issue after all, Richard... from everything you described those valves seemed the likely culprit. Still available but now about $200 bucks each. Ouch.
    http://www.autoatlanta.com/porsche-p...-69/107-35.php
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
  4. #14
    Junior Member
    Mar 2011
    Australia
    Sorry that I didn't look this up earlier. I used an ebay aircon recharge gauge. (I was running my spare 2.7 in the car at the time.)
    Name:  sporto vac pressur.jpg
  5. #15
    It’s available here as well. http://www.einmaligparts.com/Check-Valve1_p_84042.html
    Are these not repairable, is the valve just sticky? Maybe some releasing fluid will free it.
