Thread: Electrical Grounding Point Locations?
    Hi Folks. I have to find a place to ground an electrical connection toward the front of the car. I know the two battery straps grounds, but the wiring diagram indicates two other major groundings (89 in your wiring diagram program). They appear to be somewhere upfront, maybe under the dash? Anyone know their specific location? Thanks for any help you can provide. Mike
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Biggerunn View Post
    what modelyear is your vehicle?
    There should be one located to the far right under the dash behind the gauges if my memory serves me correct. It’s accessable from the front trunk area if you remove the bulkhead cover which covers the HVAC system.
    1969 911 E #824
    Well... I meant to say what year car. I guess it got left on the cutting room floor. US 1973.5T. Thanks, and I'll take another look behind the gauges.
