Results 1 to 10 of 10
Thread: Ground wires attachment point
    Senior Member lopena's Avatar
    Apr 2003
    New Jersey
    Car is a 1969 911S. There are three brown ground wires in the engine compartment near the CDI Box. I realize ground wires can be connected to any good grounding point but what is the correct factory mounting point for these three wires?
    Many thanks as always,
    Alan
    N.J.
    Alan
    N.J.
    1964 E-Type roadster
    1969 911S
    1988 328GTB
    2002 Maranello
    They all attach to the 8mm ground stud.
    Oct 2010
    Southern Ca.
    I think the stud is in front of the CD unit . ( towards the front of the car )
    This is how it looks in my very early -69 S.
    /Fredrik
    Apr 2003
    New Jersey
    Thank you Ed, Fredrik and Richy!
    I used my phone camera to survey the area and found the grounding stud between the fuel filter and the CDI box on my March, 1969 911S.
    Alan
    N.J.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    how long have they been off?
    Apr 2003
    New Jersey
    Ed:
    The engine was dropped last year to complete a full-body restoration. That’s probably when they were disconnected.
    Since then, the car has only been driven about 50 miles and runs very well (in spite of the disconnected ground wires!).
    I haven’t yet checked whether brake lights, rear window defroster, etc. are all working. Those ground wires must be connected to something!
    Alan
    N.J.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    those are grounds for relay board, cold start solenoid, rear defrost and license lights.
    Apr 2003
    New Jersey
    Okay...that makes sense since I haven’t used the rear defrost or cold start solenoid, nor have I checked the license plate lights...but wouldn’t having the relay board ground disconnected cause some sort of a problem? Unless, of course, there’s an alternate ground...like the mounting bolts, for example.
    Alan
    N.J.
    Alan
    N.J.
    1969 911S
    1988 328GTB
    2002 Maranello
    It could if your CD box was on the relay board, but it is on metal brackets.
