Results 1 to 10 of 19
Thread: Fuel and oil cap differences
    The Netherlands
    Hello,
    Looking through my spare gas and fuel caps, found quite some differences between them.
    Oil, double OIL marking vs single and rear with and without indent. Which MY can we put on them, which one would be correct for 1973? I have a feeling the one on the left..
    The Netherlands
    oil cap
    Gas cap, front side the same, rears different. MY for each?
    Cees
    Senior Member patrick911's Avatar
    Mar 2007
    Melbourne, AUS
    Hi Cees,
    my row 1973 2.4T has the bottom variant for the gas cap, though text is no longer legible, and another variant of the oil cap. the back looks like the left one, but there's no "oil" on the front at all.
    Member #3508
    1973 911 2.4T
    1976 911S -> 2.8RSR replica
    "if nothing goes right, go left!"
    The Netherlands
    Thanks Patrick, any other 73 owners, preferably with Italy delivered cars?...those seem to have more odd features like different indicator/low high-beam SWF stalk (911.613.303.30 vs 301.30).
    Cees
    Dec 2011
    Monroe, WA
    If your car is CIS, should it be vented, (Luftung) or unvented (ohne Luftung)?
    Also: some caps have OEL stamped, are those o.e., or VW?
    "Fahr drauf, bremsen ist feige!"
    My Italian 73S, 10/72 build, has the upper gas cap. My oil cap is blank.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    The Netherlands
    Thanks Steve, I was hoping you would respond, great. More 1973 owner's?
    Cees
    Cees did you find a source for the ashtray buffers?
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    Mar 2007
    Melbourne, AUS
    Just to confirm Cees, but you probably already knew, my car is an Italy delivered one as well; it still has the different front indicator lenses (more white), no emergency warning lights and a different horn.
    Member #3508
    1973 911 2.4T
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Mine too is Italian delivered 2/1972. Same no hazards but not correct oil cap as mine has ooooo on it , Audi I assume.
    Can in slightly diverge now I have two fellow Italian cars here , I’ve no details of my car from 1972 to 1983. Is there anyway I can find out it’s Italian delivery details like Registration Number. I’ve got the COA but that’s not much.
