Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 100
Thread: How to lose 150+ lbs in a few weeks! 1967 911S race car
  1. #71
    Senior Member Fubawu's Avatar
    I forgot to mention , the fuel cell went bad and was replaced. It was a Fuel Safe Porsche specific 15 gal cell and weighed 29lbs.The bladder was toast and had become sludge. I replaced it with a ATL Bantam 15 gal. It is the lightest on the market and saved almost 10lbs.
    That brought the weight down to 1835 for my estimates.
    So after all that I was off by 25lbs. I did a few little things along the way, removing the horn button, cage padding on the passenger side etc. All that with the undercoating removed must have added up to the 25lbs difference
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  2. #72
    May 2014
    Canada
    Awesome work. Good luck this weekend.
  3. #73
    Feb 2003
    Los Angeles
    Great job!
    Is the total weight with fluids or dry?
    Here is a wheel weight chart for reference:
    https://members.rennlist.com/911pcars/WheelWts.html
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
  4. #74
    Thanks guys,
    Bert ,In regards to fluids car has all fluids minus fuel.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  5. #75
    Restless minds want to know how your weekend went.
  6. #76
    Not great, I had an issue with the fuel cell and need another part. All things considered not a big deal. Silver lining , ​I got to spend more time helping my son who was racing
    at the same event in his F1600. This car he rebuilt over the winter, many small gremlins to chase. Long story short it was a weekend of short stints
    on track followed by long stints in the paddock. My next event will by Tremblant July 10th,11th ,fingers crossed I get the part from the US in time!
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #77
    So a shakedown weekend for the cars. What engine is used in your F1600?
  8. #78
    its based off the Ford pinto 1.6. Its built to make about 110 hp and weighs 950 lbs
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  9. #79
    Well I've been debating what other changes I can make that will shave those last 10-15lbs. I want to keep it peiord correct..ish
    On the list so far
    Part est Weight savings
    -R Door handles 1 lbs
    -Rain hats/shield 2 lbs
    -Sparco Light race harness 2 lbs
    -Aluminum tow hook rear 0.5 lbs
    -Fuel pump switch from Holley to Faucet 2lbs
    -Calculations on switch from 15x6 rear to 15x7 + wider tire +1 lbs
    A couple other options would be to remove the aluminium rear quarter trim and glue it in. For the savings I prefer
    the frames. I also thought about taking the head liner out and still might. I could glue in perlon, savings would be approx 2lbs.
    Lastly I'm switching out the front "R" style turn signal deletes for std lenses and plasticg horn grilles. Not sure if it will make any difference
    other than cosmetic.
    I'm open to any other thoughts but I'm still approx 6 lbs short.
    Cheers
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  10. #80
    Here is an image with decals, forgive the ride height as the car is not set in these pictures.
Size:  83.8 KBName:  201489287_4785021221524620_671779971489961423_n.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
