Got around to removing the rear wheel studs
Replaced the 100mm for 72mm.
Turns out it saved just over 0.5 lbs. Not bad as its unsprung weight and only the rears. Something to think about when ordering longer studs.
0.5 saved 1846 lbs total
911 1967S 308470
[B]911 1965 302962 Polo Red
911 1965 300760 White SOLD
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
Front suspension going back in
911 1967S 308470
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
Swamped out the oil catch can. Went with the original washer bottle over the custom aluminum set up. Saved
1lbs.
1lbs saved total weight 1845 lbs
Car goes into paint this week.
911 1967S 308470
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
Hey DAVE YOU ARE RIGHT!! these are 3.5 spacing! What a PITA as my aluminum mounting brackets are set up for 3.5. I was wondering why the new Alu Brembo calipers wouldn't fit?
I thought it was a caliper depth issue or rotor issue, the obvious option would be bolt spacing. Just a brain cramp on my end. I'll need to get proper SWB mounting brackets ASAP.
911 1967S 308470
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
911 1967S 308470
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
Great project! What are you going to use for the interior rear view mirror? If you use the standard mirror then you could possibly loose a few grams using the 914/6 smaller version.
Cees
911 1967S 308470
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
This 914/6, some say RSR used them as well is only 220grams and enough sight. I have one in my road/track car.
Regards,
Cees
