Page 3 of 10 FirstFirst 12345 ... LastLast
Results 21 to 30 of 100
Thread: How to lose 150+ lbs in a few weeks! 1967 911S race car
  1. #21
    Senior Member Fubawu's Avatar
    May 2013
    Thanks Scott A, I'll keep those pics coming. The fibreglass should be interesting.
    Got to the torsion bars today.
    Hollow vs solid.
    Impressive savings here, I went with a larger bar
    Front and rear so thought the savings would be minimal.
    22/30 solid to a 23/33 hollow.
Size:  68.8 KBName:  IMG_20210315_100843.jpg
    Over 4lbs saved total weight 1974.5lbs
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  2. #22
    May 2013
    Forgot to remove the passenger seat mount bracket. Another 1lbs saved. Focused on the low hanging fruit for now.
    1lbs saved 1973.5lbs car total
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  3. #23
    May 2013
    Made another easy swap today. Took out the steel front tow hook and tie down, replaced with aluminum. Saved almost 1lbs
    1lbs saved 1972.5 total weight
    Tomorrow I'm on to the battery for more savings.
    On another note I got around to the front suspension
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  4. #24
    Fun thread to follow.
    -Doug
    2022 Carrera 4S Oslo Blue
    1977 Martini Edition 924
    1989 Lancia Delta Integrale 16V
  5. #25
    May 2013
    Quote Originally Posted by skinnerd View Post
    Thanks Doug, the really interesting stuff will be in a couple weeks. Doors, hoods, stud length changes..lol
    It will be interesting to see how much FG saves vs steel.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  6. #26
    May 2013
    Big savings today! The car had an Optima yellow top small 480 cca battery. Not the typical Yellow but the smaller (possible motorcycle) battery. It weighed in at 27.5 lbs.
    I bought an anti gravity lithium which is a featherweight.
    Weighing in at....Name:  IMG_20190107_1117451546890557.jpg
    Yes 3lbs!! I figured this modern battery makes up for the added safety equipment used now compared to back in the day.
    24.5 lbs saved total weight 1948 lbs
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #27
    May 2013
    New starter arrived. The old original has served the car well.
Size:  80.2 KBName:  IMG_20210324_161831.jpg
    5lbs saved 1943lbs total weight
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  8. #28
    May 2013
    Turns out the tank had just over 6lbs of fuel in it. I dumped that and will minus the 6lbs from the total.
    This will make it a fair comparison at the end.
    minus 6lbs fuel, total weight 1937lbs
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  9. #29
    May 2013
    Well this is a job! Not sure what kind of losses it will yeild but I do know I'm loosing weight!
    Wire wheel and a grinder to the underbody.
    Will finish in matte black...a light coat
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  10. #30
    May 2013
    Well all undercoating is removed...ok 95%.
    I'm estimating ,a 5lbs drop here
    5lbs saved 1932 LBS total weight
Size:  80.6 KBName:  IMG_20210331_105423.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
