Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 100
Thread: How to lose 150+ lbs in a few weeks! 1967 911S race car
  1. #61
    Senior Member Fubawu's Avatar
    May 2013
    Thanks Cees, I think I have one and will take a look through my bins of parts.
    On another note I ended up going with original brake brackets on the front. The old setup was custom aluminum for 3.5 brakes. In doing so I added 1lbs total.
    So 1lbs added total weight 1846lbs
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  2. #62
    Which lights are mounted on your car? I mean front indicators and rear tailights. Do you have pictures?
  3. #63
    May 2013
    Quote Originally Posted by italux View Post
    Nothing is mounted at the moment, but the car has R style rears that I may modify and cover with a stock taillight lense. Car is at the paint shop now.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  4. #64
    May 2013
    Nothing to report in terms of weight loss but the car is having the FG parts fitted.
    Will go into the both this weekend and should have it back Monday..ish
    Final weigh in will be next week. Still a couple small jobs to do before the June 18th Canadian Vintage grand Prix
Size:  116.3 KBName:  192622270_340317460768641_7552172670681547646_n.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  5. #65
    May 2013
    I thought I would show a quick before and after front trunk area. I went to bare metal and repainted the front trunk area, cleaned up the wiring, matched hardware etc. I also ended up giving the
    fuel cell a polish, new gaskets etc.
Size:  61.4 KBName:  188863123_962229404615965_326280337554172230_n.jpg
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  6. #66
    May 2013
    Car will be back from paint Wed. I'll need to do a bit of assembly then on to the scales for the final weight. While at the paint shop I decided to remove the
    old door sil plates. I noticed a bit of the competition at the last Rennsport removing this so I thought I'd join them.
    Below you will see the King Hedinger car and the pic of my old sils. (Two pcs in the picture stacked together)
    1lbs saved total estimated weight now 1845 lbs
Size:  126.6 KBName:  Capture.JPG
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  7. #67
    May 2013
    Finally got the car on the ground and complete. I still need to set the ride height and corner balance but the final weight is in! Drum roll......
    1811 LBS
    I was pleasantly surprised to say the least. Now that being said we all tend to get greedy. How to trim 12lbs to get to a mythical 17xx lbs. Steel fenders that's saying something.
    Here are some pictures before the weigh in. I'll get more when the car is in its race livery.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  8. #68
    Oct 2008
    Burford, ON, Canada
    Bravo! Quite the accomplishment. Best of luck on race day.
  9. #69
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Fubawu View Post
    1811 LBS
    Fiberglass rain hats?
    Ditch the pop out window frames and glue in the plexi, ala R?
    Plastic door handles?
    Anything to be saved in wheels and tires?
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  10. #70
    May 2013
    Good points, the rears are 15x6 and will be swapped to 15x7 so I'm guessing there will be an uptick there. Though I will be able to remove the 1inch spacers in the rear. So I'm guessing with the larger tire it will be a wash.
    I had R handles and that saves a pound. Issue was the paint shop painted the handles body color. Looked poor and I forgot to mention it before paint. They assumed all white plastic handles should be painted. Lol
    I might remove the rain hats and use race style hats. (I forget the proper term)
    -I can remove the hour meter gauge
    -head liner
    -glove box door..but it's so tight to the cage I can't get to the hinges.
    There is always the option of switching the MSD boxes to
    reworked CDI units. I believe it will save 3-4 lbs but a costly 3-4 lbs.
    I can remove a few pounds relatively cheap but the last 8-9 will be tougher.
    Anyone know the difference between 15x6 and 15x7 Fuchs?
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
