Results 1 to 10 of 16
Thread: Looking for replacement carb hoses like this (Zenith TIN)
    Member dogLeg's Avatar
    Aug 2015
    SF Bay Area
    This is a hose off a 70T Zenith TIN carb, wondering if there is a source for replacement Carb hoses like the below with metal fittings - as opposed to just using regular hoses/clamps? Looking for a whole set for both carbs. If NLA, open to used.
    Tim
    1970 911T
    #3257
    Aug 2015
    SF Bay Area
    Thanks ! !
    Tim
    1970 911T
    #3257
    Nice bits but they didn't tell you that you need the 1600.00 tool made by Cohline to properly crimp these ferules I bought some similar and tried to crimp them myself, did not work
    Thanks, Rick
    In that application the ferrules are not crimped, just slid over the hose ends.
    What Ed said. I have those OEM ferrules but they need zinc plating.
    I recommend Cohline fuel hose: 7mm x 12mm and if using new ferrules then use Cohline #8001-1252. These are non-crimped installationd except for the three connections to the tubular fuel rail running between top of rear cross member.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    How do those ferules clamp the hose tight and no leaks ?
    Aug 2015
    SF Bay Area
    very helpful, thanks Ed. Saved me from buying a crimping tool - that I would only use once!
    Tim
    1970 911T
    #3257
    Only 3.5 psi fuel pressure. A small ID hose with the ferrule keeping the outside diameter of the hose from expanding when slipped onto the nipple creates a leak-proof fit.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Aug 2015
    SF Bay Area
    Quote Originally Posted by 1QuickS View Post
    very helpful, thanks Paul. Sent you an email about the ferrules.
    Tim
    1970 911T
    #3257
