Thread: Engine dieseling??
    Jun 2013
    lynchburg, Va
    Engine dieseling??
    The last two times I drove my car the engine dieseled for several seconds when I turned off the key. What is the likely cause?? Nothing has been changed otherwise. Always ran very well without issues.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    Victoria BC Canada
    You didn't say what car you have the trouble with, but typically dieseling, or run-on can be caused by an idle speed that is set too high on a carbureted engine or by low octane fuel, (fuel vapours continue to burn from heat in the cylinders). Higher octane is less volatile.
    Jones...
    early S # 2626
    '71 911T
    '05 BMW 330ci
    '22 Wills Sainte Claire
    '96 S10 truck
    Jun 2013
    lynchburg, Va
    Quote Originally Posted by Jones View Post
    Sorry--1970 911S Coupe
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    I'm betting on a bad tank of gas. Too much ethanol, or lower than advertised octane.
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    Same often happens to my 1972 S, and I’ve been told it’s due to the engine running rich.
    Would love to hear from Ed on this interesting topic...
    Here’s a generic article...
    https://axleaddict.com/auto-repair/W...-Keeps-Running
    Jun 2013
    lynchburg, Va
    I think we have a winner. Filled up with fresh tank of Shell premium and no more issues--not even a hint of run-on. Added a can of Seafoam to remove any excess carbon from cold weather driving, etc. Took a long drive. Runs great again.
    1969 911S Targa
    1970 911S Coupe
    1973 911T w 3.2
    1972 Alfa GTV 2000
    Great advice, great outcome.... congrats Frank !!!
