Results 1 to 2 of 2
Thread: What ids the correct sleeve bushing for this throttle linkage part?
    Jan 2021
    Toronto, ON
    What's the correct sleeve bushing for this throttle linkage part?
    Going over the car and noticed that this part was wobbling around. It's the linkage at the base of the carb. No bushings present. Want to replace with bronze ones. Cannot seem to find the right part. Every time I search it comes up as bell crank bushing. i have a set of those and they don't fit. dimensions are around 8mm ID by 12mm OD without the flange. Any suggestions?
    (edited a borrowed pic)
    I have these in stock, bronze bearings with flanged ends. They are SAE 841 bronze; 8mm x 12mm x 12mm long x 16mm flange OD
    I get them from Bunting Bearings
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
