Results 1 to 7 of 7
Thread: Anyone have pics: early 915 clutch cable support strap
    Aug 2020
    SF Bay Area
    Does anyone have any photos of the correct way to mount the clutch cable support bracket and strap on an early 915 transmission? This is all I can find (from a post on Pelican): not shown is the flexible strap nor the clutch cable. I believe it's function is to keep the clutch cable off the bell crank.
    Many thanks.
    - 1969 911T Ossi Blue #3981
    This is the way I do it. When I loop it around the cable I use a nyloc nut and barely snug it. If u tighten it up the metal grommet gets crushed and u won’t get it off later. Some Teck folks say u don’t need it, that it might contribute to clutch chatter. The strap doesn’t keep the cable housing off the bell crank, the bow in the cable housing does. I use it because I’m old school.
    Aug 2020
    SF Bay Area
    That's super helpful, thanks. My last clutch cable rubbed against the bell crank, even with the bow.
    912->911 conversion
    Nov 2004
    Calgary, Alberta, Canada
    Has anyone got a photo of the Bowden tube and cable properly installed and routed? That's always been a mystery to me (72 915 installed in my car).
    Keith Adams
    Early 911S Registry #906 | PCA member IG: @912R
    1969 Blutorange 912R - 912 to 911 conversion
    1969 Mercedes 280 SE (W111) Coupe
    Jun 2012
    London, Ontario, Canada
    Take a look in this instructive thread. https://www.early911sregistry.org/fo...ch+cable+strap
    Early 911S Registry # 2395
    My cable is about an inch above the bellcrank. Also note hand brake cable on that side with support strap.
    912->911 conversion
    Nov 2004
    Quote Originally Posted by NorthernThrux View Post
    Thanks Ravi!
    Keith Adams
