Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: FS: Brembo lightweight 3" caliper set
    Dec 2014
    Motor City
    Hi folks. Offering a set of rebuildable Brembo caliper cores for a 3" strut type. These are the lightweight Brembo calipers sometimes referred to as the "AM" caliper: https://www.pmbperformance.com/catal...45/6862358.htm.
    Rebuildable means that I've checked all the threads, pistons not stuck, etc. Ready for new seal kit (which I can provide) and use OR full restoration. $400 OBO shipped in the USA.
    I can rebuild these if desired, and options available (i.e. new bolts, pistons, etc.) but am offering a set of cores as-is for those who wish to DIY. Photos to come soon as I can't get them to upload.
    Rob
    Dec 2014
    Motor City
    Still available.
    Rob
    Senior Member Fubawu's Avatar
    May 2013
    Can't believe these haven't be snapped up.
    They are a great upgrade for lwb rears as well. I have a pair on the front of my 67S
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Oct 2010
    Sweden
    Quote Originally Posted by Fubawu View Post
    What do you need to do to fit them to the rear?
    Light Yellow -74
    @lagteknik
    May 2013
    You need nothing. It's a direct fit on the original lwb arm for the 69-73 rear. For SWB cars in the front it's a direct fit.
    There is a spacer to widen the caliper if you have vented disks or run without spacer if non vented.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Oct 2008
    Burford, ON, Canada
    Quote Originally Posted by gtBen View Post
    Mostly you would require much bigger fronts to keep your brake balance. Probably requires large 4 piston fronts.
    Junior Member
    Feb 2016
    will take them if you'll ship them to me in quebec city/canada, must be by the way around the same shipping price as if you had them ship in the usa
    just pm me
    May 2013
    I ran them with S fronts on my ST.
    DC70 up front and hp+ or dc60 rear.(,I can't fully remember)
    Update to anyone reading this thread...when I ran these on the rear with stock S fronts I had adjustable brake bias . This would not be a great set up as a stock replacement for lwb rears without bias adjust no matter what pad you run
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Oct 2010
    Sweden
    Thanks Fubavu and Davep. I will check the piston diameters on my options and do some math, and test fit them and check the clearance with 15".
    Light Yellow -74
    @lagteknik
    Oct 2010
    Sweden
    DC70 up front and hp+ or dc60 rear.(,I can fully remember)
    Does that work well? with or without a proportioning valve. They have the same piston diameter and the same pad size, only pad thickness differs.
    Light Yellow -74
    @lagteknik
