Results 1 to 2 of 2
Thread: Gauge Grommet Set
    Gauge Grommet Set
    Any ideas on sources for the grommets for the instrument cluster? Stoddard has some ( with 5mm smaller diameters) but doesn't appear to have one for the tach.
    Aug 2020
    SF Bay Area
    You mean early gauge seal rings for bolt-from-behind instruments (pre-1970)?
    As i recall, the 95mm seal for the speedo also stretches to fit the 115mm tach.
    https://www.stoddard.com/catalogsear...999-704-126-50
    - 1969 911T Ossi Blue #3981
