Thread: Transmission mount question
    Aug 2010
    I bought this thinking it was a NOS 65-71 901/911 transmission mount. The number on the bag is correct, but the mount is something else. The holes are 75 mm wide and 50 mm deep. What is it? A 915 or 901 Sporto?
    According to Porsche that fits 1969-71 pressure cast transmissions.
    Earlier part number is a 901 305 031 02 for "chilled" cast transmissions.
    Aug 2010
    The case is out of a 69 912. 902/16. I have 2 other mag case transmissions. One in my car and one for a friends car. Those are 69 also and this mount doesn't fit them either. I think this is for a sportmatic. The holes are offset like the one I have.
    https://www.ebay.com/itm/11389339795...EAAOSwj35dgir3
    Quote Originally Posted by Chris Pomares View Post
    Chris, it appears to be an early 930 front mount.
    I say "appears" only because I don't have a 930 front cover here to confirm the dimensions.
    The 901, 902, 911, 915 and Sporto mounts all have trapezoid-shaped fastener patterns.
    Jon B.
    Vista, CA
    I think this is for a sportmatic. The holes are offset like the one I have... https://www.ebay.com/itm/11389339795...EAAOSwj35dgir3
    The same eBay seller in your link also has a 905 Sporto front cover and a complete transmission, and the mount fastener patterns are obviously different...
    https://www.ebay.com/itm/12385159071...UAAOSwNCtdO1~H
    https://www.ebay.com/itm/11233166060...wAAOxyP4dTcg6f
    Jon B.
    Vista, CA
    Australia
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Just had a look at my 3lt turbo.
    Hole measurements are same.
    Do you have a pic of underside Chris?
    S Registry#2021
    Aug 2010
    From, Jon B
    Mine have the trapezoid pattern.
    Maybe I should ask on the Pelican Parts site. There are some turbo folks over there.
    I got a response back from Pelican also. 3 liter Turbo.
    Thanks to both of you!
    That’s a 930 mount.
