Results 1 to 10 of 10
Thread: FS: 2.4L 911E Mahle piston set
    Mar 2004
    Castro Valley, Ca.
    appear to be low mile in EXC condition. factory machining marks visible but impossible to photograph properly. faint scuffing, the worst if which is in the detail pic. $200 + postage. *** REDUCED to $150 *** *** SOLD ***
    1940 Mercury town sedan
    Mar 2004
    Castro Valley, Ca.
    reduced to $150
    Mar 2004
    Castro Valley, Ca.
    time for a bump
    Would you verify the part numbers, can't make them out from the pics.
    thanks
    We built an engine with 911E pistons, S heads, a 2.4 crank, and early Solex cams. It dyno'd on Jerry Woods dyno at over 190 hp. Great pistons to use. GLWS. Thanks.
    -Allen-
    Mar 2004
    Castro Valley, Ca.
    Quote Originally Posted by Bunky View Post
    thanks
    looks like 84V53
    As advertised 2.4 911E. GLWS.
    thanks!
    PM sent
    Mar 2004
    Castro Valley, Ca.
    thanks!
    PM sent
    you might not enough posts to use the PM function. post your direct email if you're OK w/ that.
