Results 1 to 10 of 11
Thread: Need your help, 1967S rear rotors rubbing on dust shield tabs???
    Senior Member Fubawu's Avatar
    May 2013
    Hi
    I dissasembled the rear suspension for cleaning, paint and new bushings. I also changed the rear studs which might play a factor as I had to pound them out and the rear bearing does move when this is done.
    All looks pressed and secure (pics attached)
    Long story short when I try to install the rear rotors they are rubbing on the dust shield tabs and the rotor does not want to seat all the way down on the hub?? Any insight would be great!
    I only had the hub castel nut torqued down to 100lbs oppossed to the 220 lbs needed,would that play a factor? Does that possible pull the stub through and the hub out away from the assembly?
    I'm lost here!
Size:  59.6 KBName:  186558449_200736838429257_7066160304921696361_n.jpg
Size:  78.5 KBName:  188185639_745061832845507_7525002534465454743_n.jpg
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    May 2013
    Heres a pic pre disassembly. Looks like it was an issue before?
    Is this a case of the caliper will center the rotor once enganged? I had the calipers off, so there
    is alot of play in the pad area.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    did you install the caliper spacers?
    I think you see it here
    Richard
    May 2013
    Yup, they are in. Maybe it's the wrong rotor? Anyone know the specs on the vented rear?
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Rear rotor 1967S
    The wear spec for the rear rotor is in the little white Technical Specifications book.
    There is a thread posted some years ago of slight mods to get the 944 rear rotor to be a fit for the (back then) super priced 1967S item.
    With the mods it was a match for offset, rotor diameter and thickness.
    See Eric's posting here:
    https://www.early911sregistry.org/fo...ight=944+rotor
    And a 2006 post here
    http://forums.pelicanparts.com/porsc...-rotors-2.html
    Is it possible someone used the 944 rotor and didn't trim to get the right diameter?
    Or used a 1969> rear rotor cuz it was close?
    Have a talk with Eric in Utah, he is the master for this stuff.
    Bob
    Early S Reg #370
    May 2013
    Hi Bob, thans for the info, very interesting and a great option. After reading through it I don't think the 944 rotor whould matter interms of "depth"
    It seems like the hats are touch to deep so it rubs on the sheild. I just tried cutting the tabs off the shield and it still touches the brake mounting pint ever so slightly.
    Its almost like the rotor needs a 2-3mm spacer on the hub.
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    not that it will solve your problem but to me the spacer looks to wide...if i remember correctly it is 3mm
    May 2013
    moito
    I thought the same thing, I just went back and put a 5mm wheel spacer dirrectly on the hub and then the rotor.
    It now sits perfectly. That 3-5mm gap seems to be what is needed but why is the question?
    I also measured rotor dia and it is 285mm which is stock for a swb vented
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Sure sounds like wrong rotor or you left something out of the hub assembly letting the hub go in too deep.
