Thread: Backdate fan, housing and shroud on 3.6?
    Can I install a 3.2 245mm fan housing and fan, and alternator on a '95 3.6 engine so I can utilize an earlier single piece fan shroud and an earlier overall look to the engine? If so, is it a simple install? This is primarily about visual aesthetics.
    1972 2.7 RS spec 911T, Aubergine
    1979 911SC backdate 3.2SS hot rod
    1974 914-6 2.2
    Dec 2010
    Wilmington, DE
    Yes, It can be done. There are a couple threads on pelican describing the conversion.
    A part isn't purchased until paid.
    The 9 Store LLC.
    Quote Originally Posted by mepstein View Post
    Thanks, but I haven't been able to find any threads on the subject, either on these forums, or Pelican. Can you post links?
    1974 914-6 2.2
