Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Show me your MFI aircleaner alternatives
    I hope this isn't redundant, but I couldn't find any similar threads. Over the years I have seen a number of options to the stock MFI aircleaner and snorkel although most of these were in racecars. For the most part if my memory serves me correctly...the ITG triples and single foam filters are what I have seen the most, but there certainly are a miriad of choices out there. For the purists, the factory aircleaner configuration is more than satisfactory. But apparently there are some among us that like to "go against the grain" at times. It would be interesting to have a resource that chronicles the aircleaner options for those of us that might head down that path. Let 'er rip.....
    registry# 1283
    Thumbs up
    Subscribed !!!!
    Think'n about this for years ....
    Jul 2015
    Ohio
    Many years ago I did a dyno comparison and found that the stock air cleaner/box is worth some horsepower over something not stock or even over slapping a foam or paper filter over the stacks. It seems as if the air flow inside the box has something to do with HP.
    I would bet that Porsche did some aero work way back in the day.
    Member Bahman's Avatar
    Jan 2021
    Greensboro NC
    K&N shorts, with rain shield, adapted to the MFI stacks. Better breathing (70+ rpm) and awesome sound.
    1972 911E Targa, Mostly Original
    2002 Porsche 996 C4 Cabriolet
    2005 Turbo-converted MINI Cooper S
    While I don’t doubt that the stock filter is better than any aftermarket options, is sure does hide a lot of an interesting engine. I don’t think that most of us would notice any drop in power from something like we see for the Weber’s. Sure, you would loose the ability to set your car on fire with the stock cold start system, but who still uses that “accident waiting to happen”. I’m surprised no one has offered up an aluminum set. Seems like their would be a market.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Sep 2009
    UK
    Aluminium cut plates. K & N filters and ebay springs.
    Jul 2003
    Santa Cruz, CA
    Obviously breathing (flow) is important to maximum hp at high revs but, Porsche knew what they were doing with the stock cleaner and snorkel for the street engines. Expansion and acceleration of the air through the shape of the snorkel results in cooler air temps into the mixture which has a greater impact on the total ponies achievable. Also, pulling that air from the lowest practicable points in the engine bay helps the air temp in that regard as well.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Here are my two. 73 with no intake preheat, and 914-6 snorkel. And our Outlaw with ITG’s
    Nov 2020
    Ramstein area, Germany
    Exactly !!!! Every additional degree in temperature is a loss of hp.
    Jun 2012
    London, Ontario, Canada
    Quote Originally Posted by 911int View Post
    Couldn't agree more. But in our cars, which have two large radiators at the low point and then the cylinders in the middle, the coolest air may actually be at the top at the engine grill. In the perfect world the snorkel would have been fed by a grill in the fender or something.
    Early 911S Registry # 2395
