Thread: Definitive '67 gas tank color
    Just purchased this tank. Oil sender unit identifies as a 1967. One of the sales pictures is shown below. Looks like a chip in the coating. Would appear to be bare metal, then a white primer and finally the undercoat like final paint. Am I wrong in this assumption? If I am correct, what should I use to clean off the top coat to see the true color? Soap and water, Simple Green. paint thinner, acetone? Color has probably darkened over the years but might give a pretty good estimate of color. Also thought that if I could strip off a piece of the paint might be able to micro slice to get original color. Any thoughts or suggestions.
    Name:  Gas Tank purcase.png
    Aug 2017
    el sobrante ca.
    the color you are seeing is pretty much it.... maybe a little darker than the photo shows would be correct ... see Brett's new book it shows a very good color picture of the early tank.Name:  DSCN0992[1].jpg
    Note: yoy can see that the sun exposé /time lightens the tank color not darken
    the underside below the bung hole in the picture I am showing you would be the most representative, not the faded lighter color
    My nos tank has a little more tan in the gray.
