Thread: Bellcrank ID help
    Bellcrank ID help
    So these are all early...and likely MFI, but what are the specific applications? I got them re-plated some years ago and they need to move on to new owners. I'd like to identify them as being correct for specific years if possible.
    registry# 1283
    top left is Weber 40IDA3C or Zenith 40TIN; mounted to manifold at cylinder #3
    top right is Solex 40PI; mounted to manifold at cylinder #3
    bottom left is MFI (I think); mounted to manifold at cylinder #3
    bottom right is bell crank mounted to left side of transaxle, possibly for carbs & MFI
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Quote Originally Posted by 1QuickS View Post
    Makes sense...thanks Paul!
    registry# 1283
    The trans bell crank is throttle for 915. The MFI bell crank is for 72-73.
