Results 1 to 2 of 2
Thread: Heater Flapper Help
    Heater Flapper Help
    I have the early type flapper boxes with centre arms I believe 65-67 are the any reproductions of this type on the market?
    Thanks in advance
    Ray
    Dec 2009
    Copenhagen, Denmark
    Yes there are many. I bought a stainless steel set for $100 each from Design 911 in Germany this week. Parts Klassik in USA has the correct orange heater boxesfor $400 each. Careful removing the wire. Mine was rusted tight to the nut/bolt and I snapped it. I bought all the wires and nuts from Rose Passion. I’m in Europe fwiw.
    James Hurst #1638
    R Gruppe #514
