Results 1 to 10 of 17
Thread: What is the proper finish for the front beam adjusting levers?
    Are these adjusters supposed to be black painted or plated?
    BTW for the guys knowing a lot, what company with a W made these? (I don’t know the answer).
    Richard
    Phosphated
    Quote Originally Posted by 718RSK View Post
    Phosphated
    Thanks (for confirming what I thought to see).
    BTW I visited your painter and if you have not found another sample by next summer (..) I might have worked my way through the mesh. It all depends on when I can I get the rolling body out and make space to move boxes.
    Richard
    Next question
    The big heavy caliper bracket phosphated?
    The small dust shield bracket silver cad plated or ?
    Richard
    Casting = phosphate
    Sheetmetal bracket = black paint
    Thanks.
    These parts are supposed to be silver (like the rear defroster tubes) painted?
    Richard
    Clear/silver zinc
    Clear/silver zinc
    You are a pro (to my standards ) so out of curiosity have you seen this picture?
    Since it doesn’t have the short tubes for the protection cover its a little newer (late 65 and up) but the finish looks so smooth and has a certain thickness?
    Richard
    Richard, those factory pictures were often airbrushed. I can only comment for Nov/Dec '65 and those were silver zinc with no signs of any coating.
    Post number 8, typical retouched (air brushed) photo with brushed in highlights for printing.
    Note the lack of texture on the support rod. I think they removed the short cross tubes from a early 1965 photo.
    The three variation to this under steering pan from 1964 thru 1967. The side bolted bolt fits into the short cross tube.
    Bob
    Early S Reg #370
