Results 1 to 9 of 9
Thread: 901 transmission parts
    Nov 2015
    Amsterdam, the Netherlands
    Hi all,
    I am rebuilding my 911/01 transmission. Unfortunately my crown wheel and pinion is damaged. What is the best thing to do? I hope somebody has a good used set available? It’s a 911 trans with a 7:31 crown wheel and pinion set.
    Or is it possible to repair such damage?
    Thank you for your help
    Adriaan
    Quote Originally Posted by 911E fan View Post
    What is the best thing to do? I hope somebody has a good used set available? It’s a 901 trans with a 7:31 crown wheel and pinion set.
    Or is it possible to repair such damage?... Adriaan
    Adriaan, that is not repairable, but fortunately a replacement set will not be hard to find.
    They're available new, from Porsche, or a used set from a pre-72 911 (except Sportomatic), a 912 or any 914 is interchangeable.
    However, you'll need a professional to install and set it up properly, or it will end up looking like the set you're replacing.
    Jon B.
    Vista, CA
    Nov 2015
    Hi Jon,
    Your comments are very much appreciated. And yes I will not do this myself otherwise the pinion will be damaged soon in the near future.
    The part is available from porsche and oem ok that’s a start. I hope not too expensive…..
    Nov 2015
    I am sorry it’s probably not much of a difference but the transmission is type 911/01 I will correct that in this post (I mentioned 901)
    Oct 2008
    Burford, ON, Canada
    No problem with your correction. Pretty much any 901, 902, 911 or 914 transmission type could be a donor.
    More than you ever wanted to know about gear failure analysis…
    https://www.rexnord.com/contentitems...108-010_manual
    Glad you should be able to get a replacement fairly easily.
    Peter Kane
    '72 911S Targa
    May 2006
    CT
    Hi Adriaan
    I have this very nice R&P taken from a clean 911/01 gearbox. I will email you more detailed photos and pricing.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Nov 2015
    Hi Tom,
    Looks good. You have my email. Thank you for your help
    Nov 2015
    Tom Butler helped me out. This is a great forum.
    Thank you this add can be closed
