Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 64
Thread: VIN 13366 RHD prototype, 8th february 1965
  1. #41
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    i built a hydraulic stamping tool for those indents...i use original porsche rocker panels for this conversion. it is not only the indents that ate different compared to the later versions. i posted an ad here--with detailed pictures--can`t find it but maybe someone has a link.
    currently have none in stock and i do not have the time to do a run in the near future
    but i sold a set to haul which he put in the shelf --just in case he would need them one day.he probably still has them.
    BTW..never use repro rocker panels!
    well…Franz…if you promise to make me another set, I will sure give mine for the sake of the proto…
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  2. #42
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by haul View Post
    a while ago porsche was short of the sill panels...not sure if they have them back in stock now....given those are available at the same price(~200€ each) i promis to make an other set for you --anyways planning to do an other run somewhen in 2024.
    feel free to get them now and next time we meet i take em home with me
    f.
  3. #43
    Jul 2014
    bavaria
    f.
    Franz,
    as spoken....your rocker set from back in the days is on the way to complete the proto....
    br
    haul
    erwin_loves_polo
  4. #44
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    [QUOTE=haul;1157904]Franz,
    br
    haul[/QUOTE
    Thanks Haul and Franz,
    Sadly I suspect it won't be the last SOS I send out. But we should be moving ahead again now.
    I am still looking for an original rear torsion bar mount. Hopefully I will find one. But that doesn't hold up progress. Will post new pictures when the sills are fitted next week.
    Graeme.
  5. #45
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    [QUOTE=GRAEMEW;1157939]
    Franz,
    br
    haul[/QUOTE
    Graeme.
    Arrived today, perfect fitName:  IMG20230731164555.jpg
  6. #46
    May 2013
    AUSTRIA (tu felix)
    Franz,
    br
    haul[/QUOTE
    what is a torsion bar mount?any pictures? what i do have are sway bar mounts...
  7. #47
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    [QUOTE=moito;1158328]
    Quote Originally Posted by GRAEMEW View Post
    I am missing one of the original shaped rear torsion bar mounts, they look like this.
    I have a new one but they are not the same.
    Name:  torsion bar mount.jpg
  8. #48
    Jan 2003
    West Sussex and The Scottish Borders
    Excellent co-operation on the sill/rocker - well done to all!
  9. #49
    May 2013
    AUSTRIA (tu felix)
    [QUOTE=GRAEMEW;1158370]
    will have a look once i`m back home---in a few days
  10. #50
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    Name:  sill rear wing joint.jpeg
    while fitting the sill I noticed where the new rear wing and new sill joined there was a bit that didn’t look right. However, a closer inspection of the original rear quarter / wing showed that this had been the same joint. On the original it had been lead filled. Presumably in the factory but it may have been when the sill was repaired and a replacement welded on top of the rusty original sill. (I think it was factory as it looked to have been sprayed signal red over the lead. But why was LEAD used as a filler ? )
    Does anyone know if that was standard practice to fill this joint. 
