Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 64
Thread: VIN 13366 RHD prototype, 8th february 1965
  1. #51
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    here is some photos of a 67(after e-coating)...original way of how it is done..i only removed the original factory lead because of potential rust issues under the lead.
    on early(64) cars i could not find any traces of hard soldering--just spot welds and torch welds- but i would recomend doing it to avoid stress cracks.
    early reutter shells where much more precise finished and not as lazy done as this 67 shows. but sill and q-panel never aligned perfect(from top view--photo#5 shows how much they where off)
    the last foto shows 300134
    on the 911R they skipped the lead to save weight...
  2. #52
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    Wink
    Thanks Moito
    Your explanation confirms what I am seeing, and what my body work guy Graham is telling me (he is not a Porsche specialist but he is becoming one. )
    The lead stays.
    The Reuter body's comment intrigued me.
    Having tighter tolerance's might explain why only the Porsche panels seem to fit this car properly.
    And when we are working on it, Graham keeps telling me how good the body is and how close the tolerances of the original joints are, he says you can easily see any repair or modification.
    I seem to have no choice but buy Porsche original panels. All the Dansk, J&P, Restoration design, etc parts are either poor quality, poor fit, or need modification.
    I have had to buy all new wings, door skins and of course sills. We have also had to cut up OEM repair panels and patch the original body work because they just aren't the same.
    Graeme
  3. #53
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by GRAEMEW View Post
    Thanks Moito
    The lead stays.
    Graeme
    fortunatly i`v had many empty 911/912 shells from the time when i broke them for spares+25 years ago solid 912 where dirt cheap...so for my restorations i could cut out entire sections from those donors..this is actually my prefered way of doing metal work. i never use dansk or RD panels...
    f.
  4. #54
    May 2013
    AUSTRIA (tu felix)
    [QUOTE=GRAEMEW;1158370]
    I am missing one of the original shaped rear torsion bar mounts, they look like this.
    I have a new one but they are not the same.
    Attachment 600753
    found a set ---freshly e coated but with visible rust marks on the surface + NOS rubber bushings i assume those bushings are carry over parts from 356...
  5. #55
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    Franz…..yessss…perfect find..��
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
  6. #56
    Jan 2003
    West Sussex and The Scottish Borders
    Bingo, bango, bongo
  7. #57
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    found a set ---freshly e coated but with visible rust marks on the surface + NOS rubber bushings i assume those bushings are carry over parts from 356...[/QUOTE]
    That's great, can you let me know how much you want for them and how much shipping to the UK is ?
    Do you have a paypal account ?
    If not Haul can give you my personal email so we can sort things out.
    Graeme
  8. #58
    Jul 2014
    bavaria
    Graeme[/QUOTE]
    email send
    erwin_loves_polo
  9. #59
    Junior Member
    Nov 2021
    Norwich Norfolk UK
    Name:  RH Inner wing marked.jpg
    This month we have been working on restoring the RH innerwing.
    We are using repair panels keeping as much as possible original.
    I notice some markings on the inner wing which intrigued me.
    I saw the same maks on one of Moito pictures so they are normal.
    Anyone know what they are ?
    Why they are there ?
  10. #60
    Jan 2003
    Vents for LHD smuggler's box? Not sure if they were there on RHD production cars? Yours is special! Best, Robert
