Results 1 to 10 of 11
Thread: Verifying Rubber Seals @ Rear Center Panel
    Guys
    Before final install and any trimming (? Not sure )
    The seal at the top edge to body seems to fit as I have shown ( please confirm) also fragile to stay in position without glue , or should be glued ?
    The seal that slides in the channel seems correctly installed (please confirm)
    Do the overhang edges of this seal get trimmed? Or do they just lay against the body return ?
    I used the silicone lubricant as shown , works great
Size:  62.2 KBName:  30049C78-660A-4B1D-A0DD-F007DABC5E54.jpg
Size:  69.5 KBName:  3C94904A-7FB3-4429-B41E-EF7FC0BF1AF6.jpg
Size:  74.0 KBName:  62177C01-572B-4F98-871C-2981B00556C1.jpg
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    I'm pretty sure the seal with the license light cutout is upside down. The license panel to body seal I install as I'm pushing the panel on, once it touches the body it will stay on. Use glue if you want to. Both seals need trimming.
    I'm very sure the seal is upside down .
    Remember, the silicone spray will help get them in but the silicone won't allow any glue to actually stick
    Thanks, Rick
    Ed & Richy
    Thanks for responses ……will turn seal over .
    The lube was only for sliding the one seal not the one to go against the body .
    Btw ….congrats to Ed on the 1st place Autocross at Parade !
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2006
    CT
    Frank
    Maybe these photos will help
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Thanks Tom…
    I now have them set in correctly
    Many thanks
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Quote Originally Posted by 71gold View Post
    Ed & Richy
    Thanks for the mention. The two oldest cars there were the 72 914-6 zoomie that got FTD, and my 72 S, in which I finished in the top 15% of all the cars there. Not too bad for a 49 year old car.
    Senior Member Bahman's Avatar
    Jan 2021
    Greensboro NC
    Ed,
    You never cease to amaze. Have not lost your touch. Top 15% of ALL CARS is stupendous.
    1972 911E Targa, Mostly Original
    2002 Porsche 996 C4 Cabriolet
    2005 Turbo-converted MINI Cooper S
    That’s amazing to be top 15%
    Interested to know your top speed and highest RPM.
    I remember my 356 autocross never above 2nd gear and think top speed was 50mph
    Don’t recall RPMs
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
