Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: What have they done to my intake...?
  1. #11
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Tremelune View Post
    I'm looking to source another cleaner that will drop right in, which in my case is plastic. My box has two holes in the rear corners, which are presumably what tube 17 is about in this diagram...Anyone know what this tube attaches to? Fire-starting cold start lines?? On my car, they're unattached holes:
    I'd do this and be done with it:
    http://forums.pelicanparts.com/porsc...l#post11407522
    Careful with the PET, not always correct for the early cars because of mid year changes or superseded parts, etc.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  2. #12
    Jul 2003
    Santa Cruz, CA
    Yes, cold start squirters and Carb boxes have different pattern/size than the MFI boxes IIRC. Also, the likely source of the problem your air box saw which would explain them being removed.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  3. #13
    Sep 2012
    Colorado
    PMO carbs don't say Weber on them; they say PMO. You have Weber's. You also have a real hodgepodge of assorted air system parts there. What are you trying to get to? I have a good plastic snorkel if you need it. I think I also have a metal one somewhere.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  4. #14
    May 2014
    South East USA
    If you are interested, below is a link, that documents a little history about Weber and PMO and R Parr.
    And that Parr had a Weber version made in USA....before he made his own PMO redesign.
    This relates to the original poster, and what he has.
    http://forums.pelicanparts.com/porsc...arb-query.html
  5. #15
    Apr 2003
    NoCal
    If you want to replicate stock factory 1970 911T you need metal, not plastic. Here is a discussion focused on MFI cars but also has info relative to your car [and I've owned several in this general range and never-ever seen plastic earlier than a late build 1971]. Particularly note on the 2nd page. Good luck and have fun.
    https://www.early911sregistry.org/fo...ious-MFI-years
